Hello guys, recently I'm playing with RC servo motors and try to play it in Simulink. I found these mechanical parameters.
The value above is default value, how can I know this value or measure them or calculate them? And I wanted to ask did RC servo motor need motor driver to control it? I'm using it to do solar tracker project.
The manufacturer should specify things like end/stop angles, speed and torque. The other parameters, probably not, since these are intended for RC hobbyists who don't really care about things like stiffness and damping. Keep in mind that there's a closed-loop controller inside the servo.
As far as I know, most servos are controlled by a PWM signal, so you don't need a motor driver-you can control it with a digital signal.
