Measuring PSRR & CMRR of Opamp
Anachip
Member level 2
Member level 2
measuring psrr
Hi Guys,
How do I measure the CMRR and PSRR of a OPAMP in Cadence tool. Please explain me in detail the way of measurement of both this parameters.
Thanks
Anachip
avinash
Full Member level 3
Full Member level 3
measuring cmrr
for PSRR measurement
use unity gain opamp.fix the +ve i/p at analog ground.at VDD give ac 1V and run the simulation.trace the o/p in frequency domain.suppose at DC your o/p is -60dB,uour psrr is 60dB.u can consult the allen hollberg book.
please click the helped button if it really helped u.
Reactions: ronello
    ronello
    V
huojinsi
Full Member level 5
Full Member level 5
measure cmrr
For PSRR simulation, generally superpose a ac signal source on the power source(ac source is series with power source), then do transient analysis, plot the Vac(the amplitude of ac signal source) and Vo ( the out of opa). From the wave of Vac and Vo,u can get Vac/Vo, its db value is psrr.
For CMRR simulation, u might refer to the picture.
puyeng
Newbie level 5
Newbie level 5
psrr opamp
avinash
the positive input should be tied to ground? but then some transistors will be cutoff, since i use power supply from 0 to 3V. Up till now i always put common mode voltage in the +ve i/p. can i?
jordan76
Full Member level 3
Full Member level 3
cadence psrr
Hi puyeng,
As avinash said, the +ve i/p is fixed at analog ground. In this case, it should be the common mode voltage which should make the input transistors stay in saturation.
Hope it helps you^_^
regards,
jordan76
puyeng
Newbie level 5
Newbie level 5
measure psrr op amp
ow.. yap.. thanks jordan76
btw, may i ask some other questions in this topic?
i've been doing the PSRR simulation with definition: PSRR- = Av(vss=0)/Ass(vin=0)
it means that when i measure Av, i put ac signal at i/p +ve of unity gain op amp, and when i measure Ass, i put ac signal at the vss. is that the correct way of doing it?
what is the value of the frequency when people say psrr at high frequency?is it at GBW of the open loop op amp? what psrr value at GBW is considered high?
i need to improve the psrr of my op amp, but since it is most influenced by Av, i could not just implement the technique right away.
looking forward to the answers. thanks
daicamuoi
Newbie level 1
Newbie level 1
Re: measure psrr op amp
hi!
can you give me an example detail to plot PSRR transfer ?
i''l read a example in "CMOS Analog Circuit Design.2e.by P.E.Allen" but HSPICE dont' plot the transfer function of open-loop configuration of Opamp.
can you post a file detail .sp of SPICE ?
thanks !!
