Measuring difference between current in live and neutral
cupoftea
Hi ,
We wish to use this CT for detecting if the current in live and neutral is the same....and if different, how different?
Supposing there was 30mA of difference between live and neutral, then do you know what the output would be of this?
ZCT409 torroid Current transformer
Read the data sheet (below):
According to that, it outputs 125-150mV into a 150Ω load with 500mA difference current, thus with 30mA current you would get 7.5-9mV.
Thanks, it strikes me that we have chosen totally the wrong torroid CT for this job. Our current is only 16Arms.......so we are seriously sacrificing resolution by using this torroid (ZCT409), which is rated to 225A...would you agree with this?
Also, the inner diameter is 24mm......and our live and neutral conductors are each only 3mm diameter....as such, they barely fill this torroid. Would you agree that really the inner diameter should be just big enough to fit on the conductors that go through the torroid ring?
So do you agree we have chosen totally the wrong torroid.
I reckon we are going to struggle to read 7.5mV to 9mV. The noise could drown it out. Do you agree?
Yes, I agree you should use a CT rated closer to the maximum current you will have.
It will give you more output voltage for a given current imbalance.
A 225A unit is definitely extreme overkill.
Why was such a large unit selected?
To measure difference between Live and Neutral you have to run both wires through the CT.
The resulting current is just the difference. No need for the CT to be rated for load current (16A).
If you safely want to measure 30mA then with a lot of headroom you may use a 100mA CT.
If you want to measure difference current up to 16A, then use a 16A CT.
Thanks, i am confused why our contractor has selected a ZCT409 , which is 225A rated, and has an aperture way bigger then the two conductors going through it....do you know why he might have done this? For an EV wallbox application, surely as you say, its just the difference current we are interested in?
--- Updated ---
Also, in the ZCT409 "datasheet" of the top post, there are 4 wires coming out of the ZCT409, but it doesnt tell what each wire is for?
--- Updated ---
Do you know a typical CT torroid for detecting earth current, and live/neutral imbalance current in 16Arms EV wallbox's? I am thinking they must be high volume, well known parts now?
I agree that the purpose of the four wire connection is unclear. A professional designer would ask for a complete datasheet and otherwise avoid the device. If your contractor selected the device, ask him for consistent data. May he can decipher the chinese text on the product drawing?
Thanks,
I have just done the following test with a ZCT409 CT torroid.
I put conductors carrying differential , equal currents through it as shown, but i get an significant output voltage from the wires that come out of this torroid.
I should not get an output when the currents are equal. Why do i get an output?
(Just to note, i get an even bigger output when i reverse the direction of one of the wires.)
Note:
In the test, the secondaries are shorted by the orange wires, and i raise the variac output volts till i get current flowing in the shorted secondaries.
The setup doesn't make sense. There's no guarantee that the current from two output windings is equal. A useful residual current mesurement setup would use forward and return wire of the same circuit.
How about the discussed four coil terminals?
I buzzed them out and found which were connected...then put the resistor on one pair, then the other......i just presumed that the wires were the ends of a "secondary" coil.....4 ends, so two coils.
Yes i realise they may not be equal currents in the above picture, but i would have thought reasonably equal, since its a dual secondary mains transformer?
--- Updated ---
..Thanks, yes, and we could easily do that if we load the device output...but with 240VAC mains, and a 16Arms load...thats wasting 3.8kW , and with multiple test jigs in the production facility...we are going to use too much power in the production facility.
--- Updated ---
Actually, sorry you're right, i just put the ZCT409 with go and return from one secondary going through it, and i get zero output from the ZCT409 CT torroid
Thanks, yes, and we could easily do that if we load the device output...but with 240VAC mains, and a 16Arms load...that's wasting 3.8kW , and with multiple test jigs in the production facility...we are going too use too much power in the production facility.
Given that the test is only for ~ 15 - 30sec the ave power is very little indeed
If they are barring this test for real power reasons, but still want 230Vac @ 16A rms - then they have set an impossibility unless you choose for a load an inductor with XL = 14.375 ohm ( i.e. 45.76 mH @ 50 Hz ) = 16A ac for 230Vac applied, this will be a largish inductor of several kg
Thanks, thats a good idea about the big inductive load.Though i am not sure where we would stand with the actual high current still coming into the factory when we have multiple production test lines running in parallel.......this is the problem....the high number of parallel production lines all wanting the high power test.
We have live and neutral wires going through a torroid aperture, each carrying 16A maximum
The torroid is wound with a 100 turn coil.
Whenever live and neutral currents are not the same, there is obviously an output on the 100 turn coil.
We wish to tell when the live and neutral conductors are >30mA (RMS) different. (ie, its an RCD function)
Whats the best/smallest circuit to allow this measurement? (measuement will be by ADC of micro)?
We obviously cant diode rectify the coil output it as the diode drop would give inaccuracy.
Obviosuly when the live and neutral are 30mA in difference, we will get an output of 300uA out of the coil.
I wouldn't bank on getting 300uA for 30mA difference!
However, the usual method of converting current to a voltage is to use a resistor! It's usually called the 'burden' when used in this application.
To linear convert it to a voltage an ADC can read, use a precision rectifier circuit and an amplifier if needed.
Is it 1:100 though?
You have a wire passing through it and you have turns around it. To make it 1:100 you would need a complete turn on the primary side. Even then you would have losses to take into account.
Is it 1:100 though?
Thanks, you have put a very poignant point forward there....i am now wondering just what turns ratio we have with a 1:100 CT?
From knowledge of 1:100 CTs used as sensors in SMPS, you are right, they are an actual full single turn wound fully round the bobbin..not like just a wire going through a torroid aperture....
..you have opened up a whole wraft of thoughts in me...for example....RCDs work by sensing >30mA of difference current between line and neutral, -they work by passing line and neutral through a torroid aperture...so how do they manage to sense the difference current with such accuracy?........they cant possibly know what "real" turns ratio they have?
You are right, when you have a simple wire passing through a torroid aperture, the leakage flux must be all over the place....i am going to have to start by looking how RCDs work?
Measurement error of a CT doesn't depend much on the primary winding geometry, it's mostly caused by finite core permeability, secondary winding and burden resistance. You need to know the core and winding parameters for a reasonable calculation.
If you have send and return current of mains going thru CT ( i.e. one turn each way ) and a difference of 30mA
what you will see on the 100T wdg is 300uA, with a 1k burden resistor this becomes 300mV rms ( and 100 times less on the 1T side )
You need to design the CT for the worst case imbalance you want to measure AND protection in case the phase is shorted to earth, lets say you get 600A pk in this case ( no return current ) the sec side has 6A rms - which thru 1k = 6kV ( this is why you never run a CT open ckt on the sec )
So you can see - there is a bit more to design for longevity, as the peak volts for 30mA are 424mV you can use 2 x 6A6 diodes ( inverse parallel ) across the sec to give protection, namely about 1V max for 6A thru, which is 1mW in the 1k res, ( not 36kW pk as before )
As said above you can use op-amp ckts to rectify and average the output to detect 30mA or read it into an ADC and let the software compute the ave or rms, you would need to sample at least every 1mS for a decent result.
Also you need to design the CT for reasonably low flux at 300mV out 50Hz - this aids accuracy.
