Pictou
Member level 1
- Joined
- Mar 19, 2013
- Messages
- 34
- Helped
- 5
- Reputation
- 14
- Reaction score
- 5
- Trophy points
- 1,288
- Activity points
- 1,570
Hello,
I tried to search how to do it on the forum but every open-loop gain calculation I found were related to amplifier only.
So here is my question, I designed an oscillator (pierce oscillator with quartz) with CMOS transistor. I would like to measure the open-loop gain and phase at the set frequency. My circuit is an amplifier inverter loaded by a quartz with 2 capacitors.
My question is how should I measure the open-loop gain?
For now I used two methods :
1st method :
Opening the loop at the gate of the amplifier, add the same amplifier at the end of the quartz so it can see the same load and measure the gain at the output of the crystal. Used a HB analysis.
2nd method :
Used a stb analysis (middlebrook), however I'm doubtful about that technique as it is used to know if the circuit is stable or not (and I'm using an oscillator which is unstable).
With the 2 methods I have 2 different results on the gain, I don't know which one to believe.
Thank you.
1st method :
2nd method :
Thank you.
