welljim
I'd like to measure signal strength across a wide frequency range, from LF to 3-4GHz or so. Is there an ultra wideband tuner IC, with RSSI output, that I can use to do the job? I could combine a few if required, to cover the desired frequency range. If that's not available, what kind of circuitry would I need, to tune a standard RF Power Detector (i.e., something like a AD8313) to the frequency that I'd like to measure, before reading its RSSI output? Either way, an MCU would step the tuner across the desired range, and sample the RSSI output with its internal ADCs. Thanks
