Hi evryone
my problem is that i want to measure the signal strength of the signal received by my WLAN card,i have used NetStumbler but it only makes a graph of SNR out of it. what i want is to measure the exact value of SNR of signal strength. ive also read somewhere else that it can be done in C++ . if anybody knows how to do this thing. its urgent !!
I do not think that this is a matter of what programming language you use. Generally the point is, is this information available on the card bus. Any language that can read the pc hardware should be ok. Maybe if you stated the manufacturer and model of the card, someone may have specific knowledge of this.
but the problem is that i want to collect these values of signal strength automatically .. so that when i start gettin different values , i can store them in a text file of somewhere else , in readable format.
i want to use these values somewhere else at later stage of my project.
is thr anything i cud do to read these values ??
is there any coding done to read them , in C++, matlab or assembly ??
i have the C++ code for this above mentioned WLANINFO.exe but its not working .. a lot of errors are there and some files are missing !!
can anyone help me out, solve this problem ??
its urgent !!
May be a problem of your toolchain and available API libraries? Basically the program is supposed to use regular MS Windows API functions, so you should be able to understand it's operation and get the the missing parts from MSDN.
