huojinsi said:Connect the op-amp to follower configuration. Input a square wave signal (insure it is a small signal and the opa is in the linear region )and run transient analysis,plot the out wave. Pls see the picture!
What you mean by saying a small signal and the opa is in linear region. Do you mean that the input pulse signal need to be small swing (and not as like rail to rail in the slew rate measurement) and the linear means keep the opamp in saturation?
