I have a MCU with +3.3V output pins, I will need to power down a device which expects -3.3V signal (it takes no more than 0.5mA current from this signal, it only expectes the negative voltage level).
How could I accomplish this? should I use a P-channel MOSFET, N-Channel? JFET? do you have a recommendation for a +3.3V logic level transistor?
I also would prefer a more simple solution as barry mentioned, anyway if you prefer to make it with discrete components, perhaps something like the following circuit could meet what you need:
Note:
V1 is the output of uC ranging from 0 up to +3.3v, and V2/V3 are -3.3v and +3.3v power supplies. Blue line, control waveform and yellow line, load waveform.
