Electro nS
Full Member level 6
hello
i am using a mosfet with gate charge of 550nC , switching frequency is 16khz to 20khz , gate resistor about 10ohm
the iR2110 specifies 2A current capability , the bootstrap capacitor is 1uF (non polarizied) ,
1-how many mosfets in parallel this chip can drive ?? ( is 4 a resonable number ??)
2-do i have to increase the bootstrap cap (duty is from 0-to 95%)?? do i have to added 10uF polarizied as i have seen in some posts online ??
3-and if it works in halfbridge configuration so: 8 mosfets and 1 driver , how much maximum dc current should the 12v regulator supply ??
thanks and regards , any info, answer or guidence to an app note is appreciated
