Matrix transistors switching circuit
lukee
Junior Member level 3
matrix transistors
Hi all,
I have big problem with my circuit (in attached file).
Problem is that when bipolar part is turn on, on the second mosfet (gate is connect to gnd) flow little current (for very short amount of time). What can be wrong and how can I solve my problem??[/img]
diode matrix switching
what do you want the circuit to do?
what is the circuit doing?
Circuit is the dot LED matrix driver it drive 3 column of LED (on each column is mosfet). Bipolar part is for PWM for LEDs (diode on schematic is LED diode) and mosfet part is for scaning column (in one time only one mosfet is turn on). Problem is when I drive only one column and on rest two LED are also little shine.
so which signal turns on your mosfet and which mosfet turns on which load, in the schematic you provided?
