MATLAB questions about using PI controller at Simulink
ramone
Member level 3
Patras University
MATLAB question!
hi there!
i would like to ask 2 matlab questions..
a) i want to use a PI controller at Simulink... obviously the Continious time parameters are different... My values are Kp=6 , Ki=2... What values should i enter at simulink???
b) i have a vector of elements and i want to subtract it at a point of the block... i don't want to have the block in simulink but i construct in Matlab were i use transfer functions... what have i to do so that i subtract this vector and the continoue construction the block??
thanks a lot!!!
Re: MATLAB question!
Can you provide a little more information? What does your model look like and what is your transfer function?
This "block" you are talking about, is that your transfer function block ? And you want to substract it's outputs ? There are a lot of function blocks for math for you to use. Maybe you should construct a new transfer function instead...
/Johan
reg. this, u mean using both matlab and simulink for the needed calculations and blocks is it??? pls be a little clear..
@ramone>>>> nevermind, could u pls explain what u needed actually so that i could clarify something incase i am not sure abt wat u r talkin abt!
/cedance
Maybe you should write and scan your block diagrams and formulas so we can help you.
guys its ok... i've tried out and found the solution i was asking for
thanks a lot for you willing to help
PI controller's parameters are determined based on the system dynamics you wanna get.
