MATLAB program for SFDR!
jeniffer
Junior Member level 1
matlab sfdr
Hi all,
I am trying to simulate ADC for SFDR,SNR,THD and SNDR. The MATLAB code is attached as below. I am new in MATLAB and couldn't fully understand the program.
To simulate, I input low frequency sinewave signal and the ADC is running at 50Ms/s. Should I take the output from the ADC or do I need to connect the output of ADC to an ideal DAC and use the output from that ideal DAC and run the program below?
(1) Can somebody explain the program below.
%Span of the input freq on each side
%span=5;
span=max(round(numpt/200),5);
(2) When I run the program, it shows error and I don't know how to fix it! Can somebody correct the program below to be used in 10-bit ADC at 50MHz clock frequency.
I appreciate any helps.
%%matlab code to calculate SNR,SNDR,THD SFDR
%%date : 11 July 2005
%%rev : 1
fclk = 80e+6;
numpt=32;
numbit=3;
load test.dat; %load data from disk
a = test';
N=length(a);
%[M,N]=size(a); %number of data
for i=1:1:N;
c=int2str(a(i)); %change integer type data to string type
temp=0;
Nlength=length(c); %length of the string;
for j=1:1:Nlength;
d=str2num(c(j))*2^(Nlength-j); %binary to dec
temp=temp+d;
end;
code(i)=temp;%/numpt*2.5;
end;
N=length(code);
%plot results in time domain
figure;
plot([1:N],code);
title('TIME DOMAIN')
xlabel('SAMPLES');
ylabel('DIGITAL OUTPUT CODE');
zoom xon;
%recenter the digital sinewave
Dout=(code-(2^numbit-1))/2;
%if no window functionis used,the input tone must be chosen
%to be unique and with regard to the sampling freq.To achieve
%this, prime numbers are introduced and the input tone is
%determined by fIN=fSAMPLE*(Prime Number/Data record size).
%To relax this requirement,window functions such as HANNING
%HAMING can be introduced,however the fundamental in the
%resulting FFT spectrum appears 'sharper' without
%the use of window functions.
Doutw=Dout;
%Doutw=Dout.*hanning(numpt);
%Doutw=Dout.*hamming(numpt);
%performing FFT
Dout_spect=fft(Doutw,numpt);
%recalculate to dB
Dout_dB=20*log10(abs(Dout_spect));
%plot([1:N/2],Dout_dB(1:N/2));
%display the results in the frequency domain with FFT plot
figure;
maxdB=max(Dout_dB(2:numpt/2));
%%for TTIMD,use the following short routine,normalized to -6.5dB
%full scale.
%plot([0:numpt/2-1].*fclk/numpt,Dout_dB(1:numpt/2)-maxdB-6.5);
plot([0:numpt/2-1].*fclk/numpt,Dout_dB(1:numpt/2)-maxdB);
grid on;
title('FFT PLOT');
xlabel('ANALOG INPUT FREQUENCY(MHz)');
ylabel('AMPLITUDE(dB)');
%a1=axis;axis([a1(1) a1(2)-120 a1(4)]);
%calculate SNR,SINAD,ENOB,THD and SFDR values
%find the signal bin number, DC=bin 1
fin=find(Dout_dB(1:numpt/2)==maxdB);
%span=5;
%approximate search span for harmonics on each side
spanh=2;
%determine power spectrum
spectP=(abs(Dout_spect)).*(abs(Dout_spect));
%find DC offset power
Pdc=sum(spectP(1:span));
%extract overall signal power
Ps=sum(spectP(span-fin:span+fin));
%vector/matric to store both freq and power of signals and harmonics
Fh=[];
%the 1st element in the vector/matrix represents the signal,
%the next element reps the 2nd harmonic,etc..
Ph=[];
%find harmonic freq and power components in the FFT spectrum
for har_num=1:10
%input tones greater than fSAMPLE are aliased back into the spectrum
tone=rem((har_num*(fin-1)+1)/numpt,1);
if tone>0.5
%input tones greater than 0.5*fSAMPLE(after aliasing) are reflected
tone=1-tone;
end
Fh=[Fh tone];
%for this procedure to work,ensure the folded back high order harmonics
%do not overlap
%with DC or signal or lower order harmonics
har_peak=max(spectP(round(tone*numpt)-spanh:round(tone*numpt)+spanh));
har_bin=find(spectP(round(tone*numpt)-spanh:round(tone*numpt)+spanh)==har_peak);
har_bin=har_bin+round(tone*numpt)-spanh-1;
Ph=[Ph sum(spectP(har_bin-1:har_bin+1))];
end
%determine the total distortion power
Pd=sum(Ph(2:5));
%determine the noise power
Pn=sum(spectP(1:numpt/2))-Pdc-Ps-Pd;
format;
A=(max(code)-min(code))
AdB=20*log10(A);
SINAD=10*log10(Ps/(Pn+Pd));
SNR=10*log10(Ps/Pn);
disp('THD is calculated from 2nd through 5th order harmonics');
THD=10*log10(Pd/Ph(1));
SFDR=10*log10(Ph(1)/max(Ph(2:10)));
disp('Signal & Harmonic power components:');
HD=10*log10(Ph(1:10)/Ph(1));
ENOB =(SNR-1.7)/6.0206;
%distinguish all harmonics locations within the FFT plot
hold on;
plot(Fh(2)*fclk,0,'mo',Fh(3)*fclk,0,'cx',Fh(4)*fclk,0,'r+',Fh(5)*fclk,0,'g*',Fh(6)*fclk,0,'bs',Fh(7)*fclk,0,'bd',Fh(Cool*fclk,0,'kv',Fh(9)*fclk,0,'y^');
legend('1st','2nd','3rd','4th','5th','6th','7th','8th','9th');
fprintf('SINAD=%gdB \n',SINAD);
fprintf('SNR=%gdB \n',SNR);
fprintf('THD=%gdB \n',THD);
fprintf('SFDR=%gdB \n',SFDR);
fprintf('ENOB=%g \n',ENOB);
%dynamic range specs,TTIMD
%two tone IMD can be a tricky measurement,because the additional equipment
%required(a power combiner to combine two input frequencies) can contribute
%unwanted intermodulation products that falsify the ADC's intermodualtion
%distortion.You must observe the following conditions to optimize IMD
%performance,although they make the selection of proper input freq a
%tedious task.
%First,the input tones must fall into the passband of the input filter.If
%these tones are close together(several tens or hundreds of kilohertz for a
%megahertz bandwidth),an appropriate window function must be chosen as
%well.Placing them too close together,however ,may allow the power combiner
%to falsify the overall IMD readings by contributing unwanted 2nd and 3rd
%order IMD products(depending on the input tones' location within the
%passband).Spacing the input tones too far apart may call for a different
%window type that has less freq resolution.The setup also requires a min of
%three phase-locked signal generators.This requirement seldom poses a
%problem for test labs,but generators have different capabilities for
%matching freq and amplitude.Compensating such mismatches to achieve (for
%example) a -0.5dB FS two-tone envelope and signal amplitudes of -6.5dB FS
%will increase your effort and test time(see the following program-code
%extraction).
sfdr matlab
You need to give the bit pattern. That is no doubt. Because the initial part is converting bits to the corresponding decimal mumbers. Later parts are working on these converted decimal numbers. Just go though the load function in MATLAB help (type "help load" )for the format you need to give to MATLAB. Probably you need to place the data file in the Work directory of MATLAB as complete path is not provided. The path in the work directory is given in one corner of the command window interface of Matlab software. Place you data in a text file "test.dat" and copy it into the work directory. Rest of the things will be automatically taken care AFAIK.
matlab thd
my suggestion is you can search on the web to get a free MATLAb toolbox of how to calculate the SFDR.
it can provide you more flexibility for your design, and you can get the usage easlier.
and you just need to output of your ADC and sample frequency for your ADC. it can work properly.
good luck!
thd matlab
can any body tell how to calculate the all specification of adc using MATLAB
sfdr test
Hello...
Please tell that if we vector S...n Noise vetor N then how can we cal calculate its SNR...please tell me ...waiting for your response...
thanx
Regards
Adnan
two tone sfdr
hi jeniffer,
Are you successfull with that matlab codes?
can someone tell me what is the input of this matlab code? what im asking is what input should i use to the ADC (sin wave? in what freq? a ramp? or simply a DC?) and how much samples do i need?
thanks!
writing a code is very easy. take FFT of your signal (x), then e.g. sort the FFT output (X) descendingly, and calculate SFDR as 20log10(X(1)/X(2))
