m.am
when i run the simulation in matlab 7.5.0.342. This message appears
Warning: The model 'experens' does not have continuous states, hence using the solver
'FixedStepDiscrete' instead of solver 'ode3'. You can disable this diagnostic by explicitly
specifying a discrete solver in the solver tab of the Configuration Parameters dialog, or setting
'Automatic solver parameter selection' diagnostic to 'none' in the Diagnostics tab of the
Configuration Parameters dialog.
thank you
thank you
