[Matlab] How to load string from file?
davyzhu
Advanced Member level 1
oriental
matlab load string
Hi all,
I have a file contain a line of string. The string contain a continuous '0''1', like'0100011001...'.
How to load the string to matlab?
Any suggestion will be appreciated!
Best regards,
Davy
matlab load file string
method 1.
file=input('input filename ','s');
fid=fopen(file);
A=fscanf(fid,'%e %x',[2,inf]); %*** this is what u want
fclose(fid);
method 2. (from HELP of matlab)
The first line of mydata.dat is
Sally Type1 12.34 45 Yes
Read the first line of the file as a free format file using the % format.
[names,types,x,y,answer] = textread('mydata.dat','%s %s %f ...
%d %s',1)
returns
names =
'Sally'
types =
'Type1'
x =
12.34000000000000
y =
45
answer =
'Yes'
    davyzhu
load string matlab
I suggest you store the input in binary format and use fread.
Otherwise you can use fscanf.
brmadhukar
matlab load file
hai,
there is a direct command in matlab to use it.
text = textread('file_name',%s);
or it can also read the file depending on some delimiter.
text = textread('file_name',%s,'delimiter','\n');
there are many options like this
you can see the help
lakshmish
