%%% Global Parameters
endTIME=1;
bufferSIZE=1024;
fftLENGTH=1024;
fs=8e3;
Ts=1/fs;
a1=1;
f1=1500;
phaseshift1=0;
%%% Function Block Parameters: Buffer1 (Buffer2)
Output buffer size: bufferSIZE
Buffer overlap: 0
Initial conditions: 0
%%% Function Block Parameters: Pad1 (Pad2)
Pad over: Columns
Pad value source: Specify via dialog
Pad value: 0
Output column mode: User-specified
Column size: fftLENGTH
Action when truncation occurs: None
%%% Function Block Parameters: FFT1 (FFT2)
Main -> Twiddle factor computation: Table lookup
Optimize table for: Speed
Output in bit-reversed order: unchecked
Divide butterfly outputs by two: unchecked
Inherit FFT length from input dimensions: unchecked
FFT length: fftLENGTH
%%% Function Block Parameters: Gain1 (Gain2)
Gain: 2/fftLENGTH
Multiplication: Element-wise(K.*u)
Sample time: -1
%%% Sink Block Parameters: Vector Scope1 (Vector Scope2)
Under "Axis Properties" tab:
Frequency units: Hertz
Frequency range: [0...Fs/2]
Inherit sample time from input: checked
Frequency display limits: Auto
Amplitude: Magnitude
Minimum Y-limit: -0.5
Maximum Y-limit: 3
Y-axis title: Amplitude
