Matlab code help working with boolean
ghattasak
Member level 1
Member level 1
helloi hae writtten the following code on matlab
data = randi(2^52,[64,1]);
m = de2bi(uint64(data),64);
groups = boolean(m');
in this code the matrix groups is a boolean matrix with each entry 1 bit a 0 or 1
in the first row there is the LSBs of all 64 numbers generated by the randi function
i want to store this row in a UINT64 variable
let say i have [1 0 1 1] i want it to be stored in a variable as 1011
then i want to transfer these groups of bits to the fpga
do you think this is possible in matlab orshould i transfer the codes as they are and group the 1st bit of each number,the 2nd...etc using vhdl in the fpga?
in the end i want to have a 64bit variable containing 64 LSBs of all 64 numbers and another containing the second bit of all the number and so on
i will use this data in labview DMA to fpga transfer for sequential design
and suggestions?
