math assembler functions
Ilia Gildin
Junior Member level 3
hello
I need to convert 10 bits and more binary numbers to decimal numbers in order to show them in the LCD (In C its a lot easier as you can just make it as 1*2^10+1*2^9.....) how can I make a similar line in assembler and to make the number like 4096 to be '4' '0' '9' '6' in order to write it again in C I can simply divide and use mod but how to make assembler to do the job
Take C function like this:
void uLongToStr (unsigned long Value, char * String)
  char zero=0;
  char tmp=0;
  unsigned long cnt=1000000000;
  while (cnt!=1)
    while (Value>=cnt)
      Value-=cnt;
      tmp++;
    if (tmp) zero=1;
    if (zero) * String++ = tmp+48;
    tmp=0;
    cnt/=10;
  * String = Value+48;
Compile it and see assembler listing ))) This is not more funny that use assembler today.
If value is 12 then you split it into 1 and 2 and add 48 to each to convert to ascii character and then send the converted data to LCD.
hi,
This assembler bin to ASCII works OK. You need ASCII characters for the LCD display.
Change the .txt extension to .asm
E
  • Bin2Asc1.txt
