Sobakava
Full Member level 6
I'm trying to get samples from output of a sensor.
Output varies between 1.1V to 3.8V.
My ADC (it's a 16bit ADC sampling at ~80Ksps ) has only positive external reference (VREF) input.
I used an external tempereature compensated precision 4.096V voltage reference.
Now it is sampling 0 to 4.096V . But my signal is only at 1.1 to 3.8V . So I'm loosing from resolution.
I decided shift my signal around 1 volt by using an opamp and replacing 4.096 reference by a 3V reference... But I need to generate very precise and temperature compensated -1V for the opamp.
Any ideas for my problem? Another 16bit ADC with both negative and positive reference inputs or shifting signal to the ADCs's input?
Best Regards
sobakava
Best Regards
sobakava
