Re: ROUTING problem
As a beginner its not at all good practise to go for autorouting, you should enjoy routing manually,now.
First try to route all critical (important signal) signals manually,then you can auto route rest of the signals,By doing this, you can check the feasibility of the routing and moreover you can squeeze the trace,subsequently it will be easier for autorouting.
Remember to always to route critical signals first manually,try this ,you might see the difference in routing.
Regards
Ramesh
