Making a bootable cd using nero software
aneesholv
India ,kerala
Hai all
I had copied all file contents of a bootable cd , Now I want to make another bootable cd using this copied files contents . Is it possible ? Iam using Nero writing software . Please help me ?
1) open nero
3) Select the CD-ROM (ISO) icon and click on the "ISO" tab to
configure for your data files. If you are going to create a CD that will be used on
Windows 95/98/ME/2000/XP or NT, use the below settings for best results. Once you have made these changes, click on NEW
Drag and drop your Data files from the File Browser window (right) to the ISO1 window (left).
Click the Choose a Recorder button.
The Choose Recorder window opens. Select the Image Recorder and click OK.
7
7. Click the Write CD dialog button. go to toolbar, click File>Write CD.
8
Click the Write button, after checking the write properties.
9
Nero will prompt you to name the image. First be sure to select your path. We
have selected My Documents for the folder to store this file too. Then name the image, for example 'DataCD_1', and click the Save button
10
Nero will begin the Imaging process.
Note: Click on the drop down menu to navigate thru folders and drive letters. Select
the folder/drive that you would desire to store the image file too.
Note: Type in a file name of the image. And note what directory it will be saved in for later use.
11
he next window will indicate that the burning process was completed successfully. Click the OK button to proceed.
Go on this link and follow the steps. I have tryed it and it works,
