making 89s51/52 89s8253 /8253 programmer
harishwww
Member level 3
hi experts
i want to make 89s51/52 89s8253 /8253 programmer using serial port can anybody suggest me how to build few days ago i have build 89c51/52 programmer
harish
harishwww said:
hi experts
harish
for 89s51/52 only.
Added after 3 minutes:
santoshaxl said:
i suggest you to make this one
santoshax that programmer does not work. have you tried it? Lots of problems/bugs in the PC application. The code for the MCU is also very sloppy. You may/may not get it to work, but it will be troublesome.
I WASTED a lot of time on this programmer before I decided to build my own.
not working ! i think ctownsend is correct what should i do now?
ctownsend said:
harishwww said:
hi experts
harish
for 89s51/52 only.
thanks for alarming me i was planning to make today i have same problem fren i want to make same programmer like harish .
thanks
i think he is looking for serial programmers
Added after 48 minutes:
will this work i haven't tried but here is the one
    harishwww
ya i want serial programmer but i'll try both Ianp,santoshaxl suggestion both
mr qwertyuiop415263 harishwww is a future engineer ,he/she should know how to construct a programmer from root level buying a programmer is not a solution, can you suggest him how to build a programmer ?????
qwertyuiop415263 said:
Man don't waste you time in these stuff. buy a programmer from market and make something with it. :D
Experimenting is always welcome as knowledge gained from such projects is just indispensible. No problem even one fails for 100 tries, one sucess will bring smiles and confidence in an enthusiast. Readymade products will be always available whenever one decides to go for.
Fir just ISP programming of AVR and 89Sxx a cheap USBASP may be easily modified by its firmware. The discussion of 2 pages about the topic may be found here
Cheers
whole day effort i have found this **broken link removed**
will this work pranam77 ji
i think this must be the final solution for this topic
Yes it is working. I have personally built it and was tested with most of the AVR's and 89S Series. Before that i had constructed the USBasp and then i started that thread to see wether the 89 series can be also incorporated as some chineese company had included that in their design by that time. And one fine day we had the files required for the modifications. Thus go ahead. Good luck.
well initially i have some problems with serial isp mentioned in 8052.com. it works well now. use the same circuit values, it will definetly work.
regards
kj
ya it work . i suggest this programmer with only xp2k operating system .
here is it
of course 11.0592mhz. used for both micro ocntrollers
Hi there
I have been using SmartPro S51 and quite happy with it. Its simplest and does what it says. I have tried other free serial port programmers available on the internet but dont have a serial port in my laptop. USB-Serial converters are a bit doggy for these programmers. I would highly recommend SmartPro S51 for programming AT89S devices
Cheers
