userx2
Full Member level 3
Hello
I have been struggling here for some time but not had a decent result yet.
I would like to isolate a mains sinewave for further processing and zero x detection on the low voltage side.
The constraints are that there can be no op amps or devices that require power rails on the mains side.
I am not ruling out very low power processor yet.
Whilst this seems simple with 2 optos at first, their current transfer ratios vary so much (>100%) that I cannot rely on a simmetrical sinewave on the other side.
I have not been able to source any isolator that has 2 matched leds and outputs or a device with a guaranteed transfer ratio.
Those HCNR300 types are not of any use here since as they are just as bad without the compensation of the second photo diode.
Unless someone knows of a more suitable opto, I think the only solution is to get the whole signal through a single opto. I can fullwave rectify it and send it through one opto but then I have no solution on re-assembling it on the other side.
I could use the rectified signal but I have found that low pass filtering that as is does not produce satisfactory results.
The signal distorts and then there is the phase shift as well...
I cannot use a transformer for this application either.
Could I somehow sample the mains with a small processor and transmit the data through the opto?
I think then the problem is sampling the negative half.
Any ideas are greatly appreciated.
Regards
X
Regards
X
