wafer101
Member level 4
The easy way would be to buy a cheap, disposable camera, with a flash, take out the flash driver (inverter, HV cap, Xenon tube etc..) and simply cut one wire going to the Xenon tube, and insert a large handwound coil (air core). Most seem to wind it around the spool of a VHS tape, making it 2" by 1". Alternatively, buy a Xenon strobe, and use that. Either way, the Xenon tube is used as a high-current switch, since we're discharging a 400uF cap at 330-400V in about 10us
I tried this but the magnetic field created was quite small (compass nidlebarely movig about 5-10 cm away)
original q) here:
original q) here:
