[SOLVED] Magnetic levitation not working
HighTechPower
Member level 5
Hi. I'm designing a magnetic levitation board based on schematics attached herewith. However magnetic does not levitate. I checked with scope and voltage signals looks normal. Any idea where's the issue. Plz note that Q1 is P type used IRF9640 and lights up the LED as normal when magnetic is above board.
--- Updated ---
Plz note only change I done is used X1 & X2 coils for L1 and Y1 & Y2 coils for L2 where Xs and Ys represents horizontal and vertical directions respectively.
--- Updated ---
--- Updated ---
Hi. Another thing I did not used R14, R16, C3, and C4.
Now I also installed the said resistors & capacitors however still no levitation.
that's rather amusing - what are you trying to levitate - a small needle ?
--- Updated ---
where did you get the information? Did any one assure you the circuit would work?
what are you trying to levitate?
please show a few photographs of your device
