magnet_placement command in dc_compiler
TonyLS
Member level 3
Boston, MA
I'm using dc_compiler revision 2010.12-SP2. Does this revision still require an incremental compile in order to use the magnet_placement
command? I know on past revisions an incremental is needed for magnet_placement.
I believe that 2010.12-SP2 eliminates the need for an incremental compile for the multi_vth_constraint command, not sure if it also applies tomagnet_placement.
Thanks
hi Tony,
I will suggest you .. to check the SOlvnet page regarding this. Synopsys always publish update training for every release .. in case there is any change version to version.
I am sure that will help you.
