omar97
Member level 1
hello all,
i have a problem in macro mapping.
i am using icc2 tool (synopsys).
i have a memory in design (SRAM macros).
i generated it from memory compiler then i used generated .lef and .db to get ndm fram view and use it in ic compiler II.
i finished the design and when writing gds i show in gds viewer (Klayout) that macros are not mapped well.
everything is mapped succefully but macros are not.
i see that a wide peace of metal 1 and 2 and 3 are a macros, there is no polysi, no diffusion, only a wide width of metal with no thing belw.
when i write gds in icc2 i give it a memory gds to map layers.
can anyone help me to solve this problem, and tell me is that flow is correct to use memory as a macros?
thanks alot
thanks alot
