eng
Junior Member level 1
assura tolerance setting
Hi all,
I'm doing an LVS on a .18um TSMC Buffer circuit by using assura. I got device parameter mismatch errors. I used Layout XL and auto generated all transistors from schematic namely whatever instance exists on the layout is its correspondence in schematic. Although the parameter deviation is very minor, I wonder why it is happening. Does anybody have an idea on this issue?
Here is Assura LVS Error log:
===== Parameter Mismatches for Instances =====
(param 1)
Schematic Instance: M2 pmos2v
Layout Instance: avD693_2 P
w 6e-06 vs 6e-06 differs by 3.53709e-06%
l 1.8e-07 vs 1.8e-07 differs by 3.79118e-07%
(param 2)
Schematic Instance: M1 pmos2v
Layout Instance: avD693_1 P
(param 3)
Schematic Instance: M3 nmos2v
Layout Instance: avD648_2 N
w 2e-06 vs 2e-06 differs by 2.52476e-07%
(param 4)
Schematic Instance: M0 nmos2v
Layout Instance: avD648_1 N
====== Summary of Errors ======
Schematic Layout Error Type
4 4 Parameter Mismatches for Instances
Hi all,
(param 1)
(param 2)
(param 3)
(param 4)
