sonofflynn
Junior Member level 2
I cannnot pass Calibre LVS on my APR block when the environment variable PEX_RUN is set to true. The design does pass lvs when PEX_RUN is set to false, however. Does anyone know why this might happen? Also can someone explain what the PEX_RUN environment variable does?
