omigaagimo
- Joined
- Dec 19, 2014
- Messages
- 7
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 61
I'm facing a really confusing problem!
I'm using old tsmc 0.18 (13d) cdb pdk in a new oa based!
I converted its data base with cadence cdb to oa and then manually reshaped techfile to solve a problem and after that everything gone right!
But when I run lvs it exits with this log
I searched the internet for solving this problem but I haven't found any!
Please don't ask me to use newer PDK release cuz as I found non of my university professors has used tsmc 0.18 libraries in newer cadence software! They say we use it for our newer PDK which are mostly 90nm based and for this reason we don't need that old PDK and we didn't get it!
I also didn't found the PDK any where else! Thus I must stick to this old version and try to solve its problem!!!
As it seems lvs has successfully finished its job but when it was going to show me some kind of POP up massage it failed!
Reading schematic network
Reading layout network
inputting network ./LayoutProcess/DIGITAL-ELEC/Nand2P/Nand2P.ldb
Preprocessing schematic network phase 1
Preprocessing layout network phase 1
WARNING (AVLVSNN-10040) : bindingFile/bind rule - schematic cell 'nmos2v_mis(MOS)' is not found.
This binding will be skipped.
WARNING (AVLVSNN-10040) : bindingFile/bind rule - schematic cell 'pmos2v_mis(MOS)' is not found.
Preprocessing schematic network phase 2
Preprocessing layout network phase 2
Top cell Nand2P schematic OMIGA-ElecDigital vs Nand2P layout OMIGA-ElecDigital
Schematic and Layout Match
1 0 9 "58 "nrpop_dis_w")
SYNTAX ERROR found at line 1 column 23 of file *string*
*Error* lineread/read: syntax error encountered in input
******* Non-recoverable error (no top-level or error handler)
******* Exiting program ...
***** nvn fork terminated abnormally *****
*WARNING* nvn exit with bad status
*WARNING* Status 65280
*WARNING* Assura execution terminated
