zoulzubazz
Member level 5
- Joined
- Apr 26, 2012
- Messages
- 87
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,288
- Activity points
- 2,040
hello everyone,
The circuit i am currently working with an INTAN IC which transmits data using an LVDS SPI bus. Isolating a normal SPI bus is straight forward if one of the many digital isolator packages are used. However isolating LVDS-SPI seems to be a bit more challenging. Is there a way to achieve this without having to convert LVDS-SPI to CMOS-level-SPI and then back to LVDS-SPI.
Also if the two step conversion method (mentioned above) is adopted what precautions should be taken to reduce timing errors, caused due to the propagation delays in ICs used to do the above mentioned conversions. Thanks very much.
