sadmak
Newbie level 5
Hello!
I dont have to much expirience in power electronics, actualy it is my first serious project.
I have an issue with circuit, based on LT8393 buck-boost led driver IC. The design works fine (it reaches the designed 30V, 3A output (the input is 12V, ~8A)), but if a current rises up to fast, the IC jumps into an infinite fault protection loop and cant get back to normal working condition, besides the outpoot mosfet (D mosfet according to datasheet) starts to heet up and the input power of circuit is biger than the output (guess there is a short somewhere).
I suppose the problem is somewhere in the feed back loop.
I have tried a lot of configurations of external RC compensations on Vc pin, but could not reach the deserved output conditions. The best configuration is C= 10pF and R = 300K, the output is 30V, 2A stabil, but further decreese of capacitance gives no result (if some on have expeerience in, how the compensation works in this circuit, i would be glad, if you could explain it to me).
Decreese of Soft start pins capacitance also helps little bit (2,2A), but in that case, the IC ruins very quickly (now the SS pins capacitance is 1uF).
There is also a mistake in design according to datasheet, but i am not shure if it can cause this situation. The point is that the diming function is not used in this configuration, and according to datasheet in this case the PWM pin (11 pin) should be tied to INTVcc pin (pin 8) directly, instead it is tied to Vref pin (pin 12). The RP pin is tied to GND.
I would appreciate any help or addvice, especially in connection with RC conpensation.
