Moonwalker
Member level 2
Have someone ever used the LT3650?
I have designed a circuit charging a 18650 battery. It works ok but the IC gets very hot (50C) at 12V input and over 65C at 28V. The IC has about 20mm² of copper on the bottom side and about 10mm² on the top side. Charging current is set to 1.5A. IC should have thermal shutdown but is this heating normal?
I build about 10 units and all have the same heat issue but now got 2 back with blown IC. Client said he plugged them in cigarette lighter socket of a truck but that should be 12V and if by mistake it was 24V it should still not get over 30V while the IC takes a max of 32V.
Any help?
Any help?
