[ARM] LPC2148 RTX-SD/MMC interface
ganesh22
Newbie level 5
Newbie level 5
Hi all,
I am working on SD card with LPC2148 in RTX-Flash system, i am using NEX-robotics board it communicate via SPI0 but the RTX uses SSP in demo codes. I have changed the demo coding to SPI0 for the configuration, I have attached my changed file and original demo code with this. Can anyone did the SD interface with LPC2148 in RTX means help me........
Thanks in advance,
Ganesh K
  • Spi.7z
The code seems to be allright...I think.What is the problem that you are facing..?
Hi udayan,
Thanks for the response actually in the code hardware selection in RTA_Config file hasn't been set properly but now the issue is solved and now i can easily write into the file and also read from that.
Hi udayan,
Hello,
can you please help me to write and read the file from sd card lpc2148 ssp.
please provide me source code.
i have attached code which simply detects SD card i want to know size and read and write to file in sd card.please help me.i'm working on this but not succeed.
  • SD_CARD.zip
Hi Rathi,
In your keil installation file itself having Demo_Code for SD_Card. you first check that one.
