LPC2148 problem when ADC1.0 and ADC1.1 work together
hbaocr
Full Member level 4
Full Member level 4
Hochiminh City university of technology (VietNam)
#include "LPC214x.H" // LPC2148 MPU Register
#include <stdio.h> // For Used Function printf
/* pototype section */
void init_serial0 (void); // Initil UART-0
int putchar (int ch); // Put Char to UART-0
int getchar (void); // Get Char From Uart-0
void delay(unsigned long int); // Delay Time Function
unsigned int count;
unsigned long int tempx,tempy;
unsigned int valx; // ADC Result (HEX)
unsigned int valy;
float voltx; // ADC Result Volt
float volty;
float ax,ay,a;
int main(void)
PCONP|=1<<20;//set PDA1 cap nguon cho adc1
init_serial0(); // Initial UART0 = 9600,N,8,1
//chon ADC1.1 = P0.8 va ADC1.0=P0.6
PINSEL0 |= 0x000033000; // Select ADC8 Pin Connect P0.6
// Initial ADC8 (ADCR=0x01210601)
AD1CR &= 0x00000000; // Clear All Bit Control
AD1CR |= 0x00000003; // Select ADC1.0 va ADC1.1
AD1CR |= 0x00000600; // ADC Clock = VBP(PCLK) / 7
AD1CR |= 0x00010000; // Busrt = 1 = Conversion Continue
AD1CR &= 0xFFF1FFFF; // CLKS = 000 = 10Bit : 11 Cycle Clock Conversion
AD1CR |= 0x00200000; // PDN = 1 = Active ADC Module
AD1CR &= 0xFF3FFFFF; // TEST[1:0] = 00 = Normal Mode
AD1CR &= 0xF7FFFFFF; // EDGE = 0 = Conversion on Falling Edge
AD1CR |= 0x01000000; // START = 001 = Start Conversion Now
//p0.6= Ax gia toc theo truc x
// Start Test Read ADC8 and Display on UART0 //
while(1) // Loop Continue
count=1;
tempx=tempy=0;
while(count--)
//doc gia tri ADC1.0=ax=valx
do
valx = AD1DR0; // Read A/D Data Register and clear DONE bit
while ((valx & 0x80000000) == 0); // Wait ADC Conversion Complete
valx = (valx >> 6) & 0x03FF;
// printf("volt");
// doc gia tri ADC1.1 =ay=valy
do // Loop Read ADC1.1(ADC8)
valy = AD1DR1;
// printf("voltx 1 "); // Read A/D Data Register and clear DONE bit
while ((valy & 0x80000000) == 0); // Wait ADC Conversion Complete
//why it loop forever here
valy = (valy >> 6) & 0x03FF;
tempx+=valx;
tempy+=valy;
volty = tempy * 3.3 / 1023.0/100.0;
voltx = tempx * 3.3 / 1023.0/500.0;
printf("voltx = %1.2f \n ",voltx);
printf("voly = %1.2f \n ",volty);
delay(10000);
/* Initial UART0 = 9600,N,8,1 */
/* VPB(pclk) = 60.00 MHz */
PINSEL0 &= 0xFFFFFFF0; // Reset P0.0,P0.1 Pin Config
PINSEL0 |= 0x00000001; // Select P0.0 = TxD(UART0)
PINSEL0 |= 0x00000004; // Select P0.1 = RxD(UART0)
U0LCR &= 0xFC; // Reset Word Select(1:0)
U0LCR |= 0x03; // Data Bit = 8 Bit
U0LCR &= 0xFB; // Stop Bit = 1 Bit
U0LCR &= 0xF7; // Parity = Disable
U0LCR &= 0xBF; // Disable Break Control
U0LCR |= 0x80; // Enable Programming of Divisor Latches
// U0DLM:U0DLL = 60.00 MHz / [16 x Baud]
// = 60.00 MHz / [16 x 9600]
// = 390.6 = 391 = 0187H
U0DLM = 0x01; // Program Divisor Latch(391) for 9600 Baud
U0DLL = 0x87;
U0LCR &= 0x7F; // Disable Programming of Divisor Latches
U0FCR |= 0x01; // FIF0 Enable
U0FCR |= 0x02; // RX FIFO Reset
U0FCR |= 0x04; // TX FIFO Reset
U0FCR &= 0x3F;
/* Write Character To UART0 */
if (ch == '\n')
while (!(U0LSR & 0x20)); // Wait TXD Buffer Empty
U0THR = 0x0D; // Write CR
return (U0THR = ch); // Write Character
/* Read Character From UART0 */
int getchar (void)
while (!(U0LSR & 0x01)); // Wait RXD Receive Data Ready
return (U0RBR); // Get Receice Data & Return
/* Delay Time Function */
/* 1-4294967296 */
void delay(unsigned long int count1)
while(count1 > 0) {count1--;} // Loop Decrease Counter
unsigned int count;
unsigned int valy;
float volty;
float ax,ay,a;
int main(void)
count=1;
tempx=tempy=0;
while(count--)
do
// printf("volt");
valy = AD1DR1;
tempx+=valx;
tempy+=valy;
delay(10000);
U0DLL = 0x87;
U0FCR &= 0x3F;
if (ch == '\n')
int getchar (void)
/* 1-4294967296 */
Your ADC1 stopped after the conversion.... Again you have to reconfigure it and START again.... I think thats y it gets hanged on your while loop....
