cupoftea
Say, you have a design with 100 Electrolytic caps on a 35V rail for which you spec 50V El caps. You need one similar value cap for the 5V rail….obviously you re-use another of the 50V El caps…..you don’t buy a single 6v3 El cap for that….
….however…
Maybe you do, because Electrolytic capacitors are not capacitors below 10% of their rated voltage? Also, they have severe loss of capacitance below 20% of their rated voltage?
What is the lowest voltage rail that a 50V El cap could be used on?
I’ve checked , and there is no capacitor manufacturer that discusses this.
….however…
