userx2
Full Member level 3
Hello
We make a lot of boards using 10 layer boards and ATMEL 9G45 processors DDR2 etc.
Heaps of BGA stuff.
Sometimes we get a great yield of say 4 failures in 500 but then at other times (now), we get 36 failures in 500. That is a lot of money.
The failures range from RAM failures to boards not booting etc.
They are mostly not repairable as we often can't find the cause.
We have to write these boards off.
I have to date not been able to find the actual cause of these problems but I suspect a problem with the actual pcb manufacture.
Now the question is, what do you other folks do to avoid these issues?
Is there some sort of bare board test I could specify to make sure the boards are at least 100%?
I do specify bare boards testing but it is unclear what the manufacturer actually does regarding that.
The board assemblies are done by subcontractors.
Any help or hints will be greatly appreciated.
Best regards
X
Heaps of BGA stuff.
Best regards
X
