Low Voltage Disconnect
scribbletojohn
Newbie level 1
Newbie level 1
I need to connect a Wireless Radio Unit (12V) to a Bus battery and prevent battery discharge when vehicle engine has been switched off
How can this be done? any ideas would be appreciated.
I was thinking about a Battery Low Voltage Disconnect / Cutoff unit or a standard DC to DC regulator. I may be wrong but this is what i inferred through searching the web.
Thanks,
John
A voltage regulator IC is a DC to DC regulator. It draws an operating current all the time that you do not want. When its input voltage is about 2V less than the regulated output is supposed to be it does not shut off the output, instead it stops regulating and the output voltage is 1.5V to 2V less than the input voltage so the radio will still be drawing current.
Why don't you power the radio from a fuse that is not powered when the ignition is switched off?
