Low Voltage current source Analysis
ccw27
Full Member level 5
This is what I got using Blackmans formula:
Rout(a=0)=ro2
Rout(short)=-A*gm1*(ro1||RoB)
Rout(open)=-A(gm1*(ro1||RoB)-gm2*ro2)
Rout=Rout(a=0) [1+Rout(short)]/[1+Rout(open)]
Rout=ro2*[1-A*gm1*(ro1||RoB)]/[1-A(gm1*(ro1||RoB)-gm2*ro2)]
Actually I believe the expression is somewhat the same if you simplify it, maybe there is a sign error somewhere.
elbadry
Full Member level 6
Egypt
I made an approx. analysis and found it to be almost:
A*Rob
I am not quite sure this is correct though.
venkateshr
Member level 3
I think it is -Rob.
a negative resistance ckt. i didnt use any blackman's theorm or other thing. strgtfwd analysis.anyway thanks for the good ckt.
Added after 34 minutes:
there is small correction . resistance is Ro1 || -Rob . i forgot the o/p imp of the mos.
Added after 53 seconds:
Ro2 instead of Ro1
pixel
Advanced Member level 2
Very useful circuit, whoose idea is to make equal Vds voltages of two pmos, which results in ideal current matching. Amplifier is just used to set DC voltage gate voltage of current current mirror gate. So I see this circuit like ideally matched current mirror.
If you want to calculate resistance you can to put at node X Itest current generator and find Vx (R=Vx/Ix). If A is high, negative feedback makes that Vtest=V+=V-. As a result of matching, both pmos will have same current, and output resistances, and through RoB will also flow current Ix, which makes V-=-RoB*Ix.
Then Rout=-RoB.
In the case of finite amplifier gain, I have used symbolic circuit solver Syrup for Maple.
Rout=-ro*(ro+RoB+A*gm*ro*RoB)/(gm*ro^2*A-ro-RoB)
pixel
Just to add:
You have two feedback loops (one positive and one negative), and I think that Blackman theorem can not help you.
    ccw27
venkateshr
Member level 3
can you please tell me waht that blackman's theorem is ? I am very curious to know that.
ccw27
Full Member level 5
Just check Gray Meyer book
