In my opinion 50µA isn't small enough, even several µA isn's small enough for subthreshold operation, you know in most of the circuits several µA is very common, so if you want your circuit to operate in subthreshold region I think the current should be even smaller.evilguy said:thanks. correct me if i'm wrong. in order to bias it in subtreshold design, vgs must be less than vt? how about the current? is 50µA can be consider small enough to drive the transistors?
hi,cherryic said:In my opinion 50µA isn't small enough, even several µA isn's small enough for subthreshold operation, you know in most of the circuits several µA is very common, so if you want your circuit to operate in subthreshold region I think the current should be even smaller.evilguy said:thanks. correct me if i'm wrong. in order to bias it in subtreshold design, vgs must be less than vt? how about the current? is 50µA can be consider small enough to drive the transistors?
jfyan said:hi,cherryic said:In my opinion 50µA isn't small enough, even several µA isn's small enough for subthreshold operation, you know in most of the circuits several µA is very common, so if you want your circuit to operate in subthreshold region I think the current should be even smaller.evilguy said:thanks. correct me if i'm wrong. in order to bias it in subtreshold design, vgs must be less than vt? how about the current? is 50µA can be consider small enough to drive the transistors?
i don't think so.
a transistor working in its weak inversion is not depedent on its current but mainly on the overdrive voltage(vgs<=vt).
jeff
szekit said:i would agree with jeff also. but this is purely academic.
in low-power design, u would like to bias your circuit in nA range with vgs < vth.
my question:
with such low current, slew rate becomes a problem. what techniques do you use to tackle it? i.e., limiting voltage swing? example?
szekit said:u can use i = C dv / dt to calculate the current u need.
I know that, but we are talking about practical applications not theories right?jfyan said:hi,cherryic said:In my opinion 50µA isn't small enough, even several µA isn's small enough for subthreshold operation, you know in most of the circuits several µA is very common, so if you want your circuit to operate in subthreshold region I think the current should be even smaller.evilguy said:thanks. correct me if i'm wrong. in order to bias it in subtreshold design, vgs must be less than vt? how about the current? is 50µA can be consider small enough to drive the transistors?
i don't think so.
jeff
jeff
evilguy said:jeff
i'm more confius now. what do you mean by that?
I think maybe you can refer to some IEEE papers to gain some useful insights about this issue.evilguy said:thanks... the main problem for me is i dont really know how to decide the value of drain current. some experience analog engineer should find this easy and can simply decide what is the value.
beckchm said:ua is the subtherhold current order
