The best way is one of those you saw in class, we cannot know which......
How do you recommend solving it?
In the first stages that exercises are solved using differential equations resources.
Later, after having learned the basis of Laplace transform, they are solved by transform-antitransform method.
And later, is not solved in time domain (L antitransform), only study the properties in 's' domain except in special cases.
Yes. But......
Now the dq/dt that was found by differentiating q made subject of the formula. i = dq/dt. do I have to differentiate again and equate to zero to get the time for the minimum current?
It's OK, but
No.
