Colon
Member level 3
I'm having trouble finding a suitable pair of transistors for my amplifier push pull output. They are being driven by an op amp output as part of a feedback loop so low source resistance making bjts best. They also need to be medium power as they supply 0.5W max each. My application operates from 10kHz to 1.5MHz, from a 12V rail.
The problem I am finding is that datasheets and manufacturers rarely give noise data unless it's an rf bjt. Then, they do specify noise figure, but they don't specify the 1/f corner frequency, so I am not 100% sure the noise will be good at the bottom end (or is 10k well above most 1/f, even for rf?).
Is there something I am missing or am I best just asking manufacturers for a recommendation based on my spec? If not, does anyone have any to suggest?
Thanks
James
Thanks
James
