ransiluj
Member level 1
I need good current sensor IC. I'm going to measure current change of the PC when software is running. Do you have an idea about how much current should it take. I mean the current that is changing. Using a good accurate IC is good way to measure that change of the current ? IC like ACS 712 is good or bad?
or is there any current sensing IC for measure micro current change or mA change?
