Low cost opamp(single supply)
myfaithnka
Full Member level 1
hi all,
pls tell me some low cost opamps woking on battery (single supply).
is it possible for lm 741 to work in single supply ?
thanks.
Yes,i can use all Dual Supply op-amps with single supply also,as long as input common mode range is not exceeded.
You can also use any "single supply" opamp with a dual supply with the same condition as above.
For detailed discussion regarding op-amp's & supply pin voltages refer to this thread:https://www.edaboard.com/threads/289723/
