Feb 19, 2005 #1 C Catalyst Full Member level 3 Joined Jan 22, 2005 Messages 167 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 1,651 hfss 12 Hello everyone, I was wondering whether anyone has managed to setup a simulation in HFSS 9.2 consisting of a loop antenna being fed by a coaxial cable. Cheers Cat
Feb 20, 2005 #2 L Le Member level 1 Joined Oct 5, 2004 Messages 32 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 291 hfss12 dear Catalyst, Loop antenna, it probably is external antenna. I think that you just use wave port to be contact with antenna materal is okay. Any ground plane (e.g PCB) for the system? you could find how to simulate the antenna in tutorial. Best Regrads, Le
Mar 10, 2005 #3 C Catalyst Full Member level 3 Joined Jan 22, 2005 Messages 167 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 1,651 Re: HFSS and Loop Antennas Does any1 have an example of a HFSS project consisting of any type of antenna being fed by a coax cable because I am getting strange results. Thanks in advance Cat
Mar 11, 2005 #4 M maverick09 Member level 4 Joined Mar 9, 2005 Messages 72 Helped 6 Reputation 12 Reaction score 5 Trophy points 1,288 Activity points 2,120 Re: HFSS and Loop Antennas Hi Catalyst, I suggest you to go ansoft.com and you will see a HFSS manual in pdf, it has an example of probe fed antenna.
Mar 12, 2005 #5 C Catalyst Full Member level 3 Joined Jan 22, 2005 Messages 167 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 1,651 Re: HFSS and Loop Antennas Cheers for that. Are there any other examples that are available ?
May 2, 2008 #6 M mvdeepaknair Member level 1 Joined Jan 25, 2007 Messages 41 Helped 7 Reputation 14 Reaction score 4 Trophy points 1,288 Activity points 1,508 HFSS and Loop Antennas **broken link removed**] this site hope it will be helpful Last edited by a moderator: Jul 19, 2021
May 6, 2008 #7 P peleda Advanced Member level 4 Joined Jan 10, 2006 Messages 110 Helped 22 Reputation 44 Reaction score 12 Trophy points 1,298 Location Monte Carlo Activity points 1,934 Re: HFSS and Loop Antennas how are you feeding your coax???
May 6, 2008 #8 yingyang Full Member level 2 Joined Dec 26, 2002 Messages 126 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 862 Re: HFSS and Loop Antennas HFSS 12 CAN DO THIS.
May 7, 2008 #9 Z zirtapoz Full Member level 3 Joined Dec 25, 2007 Messages 159 Helped 17 Reputation 34 Reaction score 6 Trophy points 1,298 Location finite space Activity points 2,072 Re: HFSS and Loop Antennas Tutorials explains how to feed coax. you can even use wave or lumped port for coax fed structures.
