Looking for schematics of good circuits with MAX038
engraxate
Member level 3
Member level 3
need a good circuit with max038
max038 generator
I HAVE TO CIRCUITS FROM MAGAZINE
FIRST IS IN LE HAUT-PARLEUR N.1846 ( DON'T HAVE MONTH & YEAR)
SECOND IS IN RADIO PLAN N. 572 PRETTY COMPLETE 3 BOARD
GEN FONCTION , AMPLI , MODULATION
LAST ONE, DON't HAVE NAME OF MAG VERSION BASIC JUST MAX ON PCB
BEST I CAN DO IS SEND PICTURE OF THE ARTICLE TELL ME WICH VERSION YOU PREFER
max038 elektor
Hi
Both elektor and EPE has made projects based on the MAX038. You can check on epemag (july2001??) and elektor had it in a # from 1995 06?.
The elektor project I built myself, I have only got it to work correctly with freq <2.5MHz, it gives freq > 10Mhz. One reason that the signal is crappy can be my loosy oscilloscope... there are freq components above 100MHz
If you like I can see if I can find the magz , here are some links:
hxx//members.ozemail.com.au/~dljones/hsfg.htm
hxx//users.swing.be/gonzague.colpaert/genfonct.html
3*w.htw-dresden.de/fe/labor/mikror/projects/siggen/index.htm
Good luck.
generator max038 circuit
there are also good schematics in the datasheet and in the maxim's app notes for this circuit.
related:www.stavebnice.net/st/a889.htm
Search Edaboard for function generator. There is Elektor article with MAX038, the good one.
max038 epe magazine
This is a good circuit.
http//members.ozemail.com.au/~dljones/hsfg.htm
This is another one.
members.ozemail.com.au / ~ dljones / hsfg.htm
If there someone who build epe's functional generator wit this max ?
I like to build it.
Here are another project with max038
