Looking for schematics of digital frequency synthesizer
mamoon
Newbie level 2
i need to make a digital frequnecy synthesizer for FM range (88MHZ-108MHZ) with 100khz step. i need the scehmatic. can i use LM566 as vco if yes what should b tha timing circuit. plz help me thanx
cwt
Member level 5
Hi there, currently i am facing the similar problem with you. Whats your frequency synthesizer going to do? Modulate signal as FM-modulated output signal?
eng_ahmed22
Full Member level 4
Re: frequency synthesizer
try to use a PLL. it used as frequency synthesizer. but i dont know the frequency range. I think u have to refere to data sheet
have a good day
Ahmed
www.i-g.org
mamoon
Newbie level 2
it will just gona synthesize any freq in this range with 100 khz step i donot have any prob regarding pll but there is no ic of vco for this range :(
fobyellow
Junior Member level 3
try to find some service manual of the Full band receiver by kenwood etc, the LO schem may help.
or else try a DDS? like AD9951, get more information at www.analog.com
satria02
Junior Member level 2
Bandung
any body ever use AD9951?
can you share your experience using AD9951?
thanks
KJ6EAD
Advanced Member level 3
Earth
I'm not sure what you need, just a VCO or a complete transmit or receive capability. Here are some links:
I just realized that this thread is 5 years old. :oops:
mesterul
Hello!
I realized 1 month ago an interface to control TSA 5522 for what you search. The firmware allows you to select the steps (50 - 1000kHz).
  • SINTEZA FCV 87-108.pdf
  • tsa_5512_mic.txt
