Looking for schematic of 1200 Watt UPS
tabassum
hi i need for pic16fxx base 1200w ups /230v/50HZ .any body can help me. thanks
1200 wat ups
ur question is not very clear
what do u mean by pic based ups?
it seems u wanna interface pic with ups
i think no ups has provided direct interface with any pic u have to design an interface by ur self
Re: 1200 wat ups
salaam abdul manan
thanks for your reply
i means around near 1200w ups diagram and sofwtare .on the microchip website available PICREF-1 . but its parts not available easy and also costly. so i need any microcontroller base circuit of ups .that input 12v or 24v .output 240v 50hz.and also monitor battery.
thanks
Re: 1200 wat ups
MODERATOR ACTION: never post roman urdu here i will ban you, only post stuff that every one understand i have deleted your post that contain roman udru "Fragrance''
check this out
if u r Pakistani
"agr samagh aa gaye to mughe bhi samgha dena":D:D:D:D:D
1200 wat ups
hi abdul manan can u plz explain me wat have u done??
Added after 1 minutes:
i guess u have worked alot in dis field
1200 wat ups
is dis sum kind of joke to you..
1200 wat ups
no but it seems it is to u
plz keep the topic formal
Re: 1200 wat ups
so you upload the same schematics from here
less some important details... and what's the use? :roll:
Re: 1200 wat ups
a lot of thanks
i thinks its a good.
1200 wat ups
please can someone explain how to generate a 50hz frequency from 16f877a
Re: 1200 wat ups
But I want a schmatic and program in PIC
1200 wat ups
if u are going with square wave just use this
output_high(pin_a0);
delay_ms(10);
output_low(pin_a0);
delay_ms(10);
this outputes the 50hz square wave.
for sine wave u have to do the pwm.and use filter on the output.
