hello,
u may use two counters one working with the refrence and the other with the feedback , and then monitor when the counter will overflow it , by comparing the two values of the counter u can know what is the diffrence between them, u can choose the counters to provid a certain accuracy
or u can use something more easier ,but not that accurate which is adding a D-ff after each of the D-ff of the PFD each one is connected to one of the two clks , this is called cycle slipping detector which will gives a one only when two consecutive edges of one of the two clocks occur (i.e. the two clks doesnt have the same freq.)
regards
