looking for projects in analog domain
alpeshchokshi
Full Member level 2
San Jose, CA
hello friends can you suggest me in which different area of analog design
for projects i can do???
please let me know
thanks
If you are want to work on some exciting topic what I can suggest is
Ultra High speed logic Design Using CML logic.
Else you can also try in ultra high speed data convertors.
If you want to begin on a lower note then try Op Amp blocks or PLL design.
Depending on your interest you can design Ultra High Speed or Ultra Low power designs.
Thanks
Shaikh Sarfraz
hi alpeshchokshi,
i would suggest you to design a Phase Locked Loop for bluetooth applications.
regards,
vijay
We have a voltage regulator with no ripples,can u analyse it? it VCC between 45...48 and output is 25 fixed,and ripples 55 db below the out put.we have'nt data sheet of transistors.
I would suggest you to design a high speed ADC for IF-sampling.
thanks for your response
i would like to interpolate more on ADC/DAC or PLL domain
so please send me some informative reference through which i can get start.
I will suggest you to start with ADC design. That gives good exposure if you are a beginner.
If you want more specifically, fora short term project, you can start from Pipeline ADC architectures. The reference paper I suggest is
A 1.5 V, 10-bit,14.3-Ms/s CMOS Popeline Analog-to-Digital-Converter
The paper is from IEEE Jouranl of Solid State Circuits, May 1999.
