Looking for PLL reference design
Death
Could anyone provide some references for lock detector circuit for the variable frequency input .
Re: PLL reference
Please google the LOCK detector of PLL, you can find the analog method and digital method, analog mathod will detect the differenct of PFD out put, and digital method will open a window.
Re: PLL reference
A Simple Precharged CMOS Phase Frequency Detector
Re: PLL reference
For Lock Detector
just use xor gate with inputs up & down (PFD outputs) if the PLL at lock the up & down will be identical & the Xor will stick to 0 other wise the Xor will toggle
you can use DFF & samples the XOR out with the reference frequency
best regards,
Rania
PLL reference
phase frequency detector is used with narrow width reset pulse there are some architerct available
baker book useds very fine PFD
